It is currently Sat Jul 19, 2025 3:02 am
PostPosted: Wed Nov 08, 2006 4:33 am
Last Name: Watkins
City: Lake Zurich
State: IL
John Watkins
CNC Guitar Parts
PostPosted: Wed Nov 08, 2006 4:34 am
Bit of a tricky repair there John!
PostPosted: Wed Nov 08, 2006 4:38 am
Last Name: Watkins
City: Lake Zurich
State: IL
Oh, I'm fine. I was eating my lunch and watching the golf channel when it happened. Ever seen a cat jump straight up about 4 feet from a dead sleep?
John Watkins
CNC Guitar Parts
PostPosted: Wed Nov 08, 2006 4:48 am
Ouch. It genuinely hurt to see that photograph.
PostPosted: Wed Nov 08, 2006 4:52 am
Yikes, looks like you might have had a clamp slip.
Horton, MI
PostPosted: Wed Nov 08, 2006 5:01 am
Ouch
Was that one of my necks?????
Wow. What kind of inlay is that for?
Glad you're OK, hope the machine is too. What caused it, pray tell?
PostPosted: Wed Nov 08, 2006 5:02 am
Dang I hate when that happens
PostPosted: Wed Nov 08, 2006 5:03 am
Dang, and I needed that neck right away too...
PostPosted: Wed Nov 08, 2006 5:06 am
Put it on Ebay. You'll be fine.....
In Markham,Virginia
PostPosted: Wed Nov 08, 2006 5:16 am
Last Name: Watkins
City: Lake Zurich
State: IL
Despite running 70% speed on this particular neck, the vacuum just couldn't hold on. Usually that bolt you see in the picture goes into one of the neck bolt inserts for added stability, but this customer (yes you, Andy) didn't want the inserts, so it was vacuum only.
The cutter is also due for a re-grind, so it's pounding on the part a little harder than a freshly sharpened one would.
J
John Watkins
CNC Guitar Parts
PostPosted: Wed Nov 08, 2006 5:19 am
ouch.....
thats a pretty scary thought!!
PostPosted: Wed Nov 08, 2006 5:25 am
Last Name: Watkins
City: Lake Zurich
State: IL
The scary thing to me is the power this thing has. It split this neck blank all the way up the middle into two pieces and send the top inch or so of the heel all the way across the shop. Yet, when I check the position of the cutter against the fixture, it is not off. I mean it is +/-.0002" from where it ought to be.
Also, you can't really tell from the picture, but that bit is 5/8" diameter and 6" long. Weighs about 2 lbs.
John Watkins
CNC Guitar Parts
PostPosted: Wed Nov 08, 2006 5:26 am
New special prices this week, Andy.
PostPosted: Wed Nov 08, 2006 5:56 am
Hey Andy, can we talk you into using inserts??
PostPosted: Wed Nov 08, 2006 5:59 am
When Chiropractors go bad....
PostPosted: Wed Nov 08, 2006 6:25 am
So John, just exactly how fast can you run down the stairs to your shop?
'bout time to get that Edwards fired up doncha think?
PostPosted: Wed Nov 08, 2006 6:41 am
Don
I do use a cross dowel and bolt system. BUT because of my fretboard
extension on top of my neck block, my 1st bolt is lower down the tenon
compared to Johns standard!!!!!
PostPosted: Wed Nov 08, 2006 7:44 am
Last Name: Watkins
City: Lake Zurich
State: IL
Paul, the running down the stairs takes no time, it's the crawling across the floor on your hands and knees to the emergency stop button that takes a minute.
Andy, the replacement is cutting now. No worries.
John Watkins
CNC Guitar Parts
PostPosted: Wed Nov 08, 2006 8:43 am
John, I think you can still use that neck. Just put "Gibson" on the headstock and stamp a "2" on the back. No waste!
PostPosted: Wed Nov 08, 2006 8:48 am
Just get a matching Les Paul body, and hook er up on Ebay as the Pete Townsend model ...
PostPosted: Wed Nov 08, 2006 9:02 am
Last Name: Watkins
City: Lake Zurich
State: IL
Wow. No mercy out of this crowd, huh? Not that Gibson hasn't earned it...
John Watkins
CNC Guitar Parts
PostPosted: Wed Nov 08, 2006 10:28 am
The kind of picture that makes you count your fingers.
                   Paul
